airspeed Posted April 4, 2010 Share Posted April 4, 2010 I was looking at the slave cylinder on my 88 AX4 and noticed some plastic locking clips where you can compress the slave cylinder and lock it in that position? Is that for new build shipping or is there some special procedure for installation? Both the clutch and slave cylinder look brand new so they are going back in. Link to comment Share on other sites More sharing options...
Pete M Posted April 5, 2010 Share Posted April 5, 2010 I'm guessing yes. My new internal slave came with little clips that hold it compressed and keep it from flying apart. they pop right off when you first push on the pedal. :thumbsup: Link to comment Share on other sites More sharing options...
Eagle Posted April 5, 2010 Share Posted April 5, 2010 You are supposed to leave it compressed and clipped when installing, and when bleeding. After the system has been bled, when you first step on the clutch the clips will pop off and things will (ideally) work normally. Don't forget to recheck the fluid level after the clips pop off. Link to comment Share on other sites More sharing options...
