wiper help
i have done something similar. the relay is bad in mine and i didnt wanna take the tilt column a part (its a pain) so i tested all the wires in hooking up to the wiper motor and figured out what they did, then i put robbers on them (so i didnt destroy the connection to the original switch) and ran wires back into my cab. i ran those to a three way switch (up for low sped, down for high speed, and middle for off) and a small push button (wiper fluid. i mounted those into a small plastic interior piece from an old car (it happened to match my interior) and viola :D now i just flip a switch for wipers and push a button for fluid. only problem is i have to turn the wipers off when their at the bottom or they sit in the middle of my windsheild, but its still better than nothing. one day i will tear into the tilt column and fix it right, but for now it works fine :thumbsup:
