Lloyd Posted March 22, 2010 Share Posted March 22, 2010 Switching transmissions in my 91' Comanche from a manual to an AW-4 automatic. I had enough time to grab the switch on the dash that says power or comfort for the tranmission. The junk yard was closing and I had only a borrowed vehicle. The wiring was already in my truck for it behind the blank panel they had in it's place. I hope the truck I got the tranny out of is still there when I get a chance to head back to the junk yard. In any case can anyone tell me where the control componets are located that I need to get for the electronically controlled transmission. And what exactly do they do? I'm stoked to get it back going again. I had a U-joint failure at one time that knocked my driveshaft out of balance and I neglected to get it balanced. It vibrated the bolts loose on my bellhousing and it ended up breaking the bellhousing. I had looked for a while for just a bellhousing that would fit and was within my budget to no avail. So whenI was at the junkyard looking for other things I was suprized to find a truck like mine except for the automatic. Any feedback is much appreciated. Only in a Jeep, Lloyd Link to comment Share on other sites More sharing options...
WBKrazy Posted March 22, 2010 Share Posted March 22, 2010 the transmission computer is mounted to the lower dash panel under the glovebox.. it controls shifting and torque converter lockup, among other things.... Link to comment Share on other sites More sharing options...
Wildman Posted March 23, 2010 Share Posted March 23, 2010 I think you better read thru this..........before you make any rash decisions....... viewtopic.php?f=9&t=12206 There are a "few" more items needed than just the TCU to swap in a AW4 :roll: I'm sure someone on here has an AX-15 bell housing for a replacement for you ;) Link to comment Share on other sites More sharing options...
comanchedude Posted March 23, 2010 Share Posted March 23, 2010 you can run the auto without the controls if you want. you have to shift it manually through the gears and back when you stop. but to answer your question. you need the computer and the wire harness and sensors that goes with it for full auto operation and converter lockup. you need the auto TPS for it to work correctly. there is also a switch mounted to the brake pedal just like a stoplight switch that shuts off the lockup converter when breaking. if you pull the complete auto tranny harness you will find all these parts. Also you will need the shifter. :cheers: Link to comment Share on other sites More sharing options...
Lloyd Posted April 12, 2010 Author Share Posted April 12, 2010 Thank You to everyone offering help to this. I made it back to the junk yard and the MJ was still there, minus a few parts but nothing that I needed. I got all the parts I needed except the TPS, Floor shifter and cable. The work is going slowly due to the time frames I have to work in and the weather sometimes not cooperating. And the family and friends who also need help. Some are priority, such as brother-in-law that had a heart attach recently, but is getting better needing his chevy truck worked on. Or younger sister's Grand Am. After I get it moving and legalized I see my next effort being the instument cluster swap. Thanks again for all the help. Only in a Jeep Lloyd Link to comment Share on other sites More sharing options...
