Another turn signal issue
Ok. When I turn either blinker on I get nothing. I know the usual is the lights on the dash usually come on but I have nothing. After I check the power leaving the fuse box what would be next in line? The steering column ?
Checked power to fuse box and going out to the Red/Blue wire going into steering column. 12v. Also, swapped the blinker and flasher fuse. Didn't help. How do I go about getting to the switch in the steering column if thats what you would recommend next?
