Old man with MJ Posted March 17, 2010 Share Posted March 17, 2010 Brakelight switch (stoplight)on brake pedal on an 88,is it still available from Jeep, don't know part no. Link to comment Share on other sites More sharing options...
mythreesons Posted March 17, 2010 Share Posted March 17, 2010 It's available at most parts stores. About $10. Make sure you get the right one, if I remember right the variance related to cruise control or not. Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 18, 2010 Share Posted March 18, 2010 I bought one at Kragens Auto Supply, it never worked properly so I took it back and got one from NAPA, it's been going for 7 years. Make sure you remember where all the spacers/bushings go if you don't have any reference material. Edit: Well, here it is if you need it from the '90 FSM. Link to comment Share on other sites More sharing options...
railroad sam Posted June 10, 2017 Share Posted June 10, 2017 Really like the diagram. Been having hell with my one owner 1987 Comanche. My problem is switch swivels. Power booster push rod end is rounded. I replaced one of the spacers with a garden hose rubber gasket and added a flat metal washer to compress when tightened. Just position switch until brake lights work and tighten. Link to comment Share on other sites More sharing options...
railroad sam Posted October 1, 2018 Share Posted October 1, 2018 Well had to replace brake light switch again. Failed state inspection. It's working again. Can only get brake light to work if I swivel the switch end toward driver down. Power booster rod end in switch is rounded. Like an eyebolt. Link to comment Share on other sites More sharing options...
