STERLING STINGER Posted March 14, 2010 Share Posted March 14, 2010 back to another problem i left my truck (88) outside in the rain last night hasnt been out just sitting in rain for a while, except driving in it just went to start it...nothing distributor ??? I'm gonna let it dry out n check it i don't think its gas any inputs? thanks Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 14, 2010 Share Posted March 14, 2010 Does it turn over and just not fire? If yes, pull the cap and CK for moisture. if you find some, spray it out with WD-40. Then check the coil on the pass fender. Is that wet? blow it off and see what you get... CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Author Share Posted March 14, 2010 if i take the plug out and ground it to the vc...i should see spark when i turn it over right? took off dc and it was a little bit dirty....cleaned it up didnt see any spark, but i am doing this alone, so i just kinda set it on the vc to look for spark :dunno: coil on the pass fender??? ill go check that now Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 14, 2010 Share Posted March 14, 2010 I would try to get a spark on steel not the alum valve cover... For the coil follow the coil wire... What do you mean "dirty" cap? When was the last tune up? Maybe its simply time for new cap, rotor, wires and plugs?!?! You did say it ran fine last nite rite?? CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Author Share Posted March 14, 2010 ya....I'm getting a buddy here to turn it over to me to get spark i know...my vc is aluminun :doh: ....for now, but i couldnt see it anywhere else while turning it over myself... the coil is wd40d Link to comment Share on other sites More sharing options...
XXLMJ Posted March 14, 2010 Share Posted March 14, 2010 My buddy had this problem, he would pull off each plug wire, at the distributor and spray a little WD in each end. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 14, 2010 Share Posted March 14, 2010 I wouldn't soak the coil pack with the WD.. just the inside of the cap!! CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Author Share Posted March 14, 2010 no spark at all drying coil and dc with hairdryer just a quick question though.....why is there oil in the bottom of my distributer??? Link to comment Share on other sites More sharing options...
XXLMJ Posted March 14, 2010 Share Posted March 14, 2010 Do you have no spark at the spark plug? Or at the coil? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Author Share Posted March 14, 2010 how do you check for spark at the coil i think that would narrow alot down Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Author Share Posted March 14, 2010 bump Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Author Share Posted March 14, 2010 got it....while i was checking the power tothe coil, i noticed the fuses looked wet. cleaned up, wd40d and were good! thanks again guys! Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 14, 2010 Share Posted March 14, 2010 Sorry stepped away for a bit... At least you got it!! Yea the WD in WD 40 stands for Water Displacement 40th version... Its designed for the displacement of water and spraying, wiping the inside of the cap is one thing its excels at!! Spraying the fuses would be just as good!! Its works well for removing some permanent markers and crayon marks too.. kinda sux for lubrication or rust prevention, but that's OK there is other stuff that works for that!! Now do something to better protect those fuses!!! If a rain fall takes you out your not protecting them enough... CW Link to comment Share on other sites More sharing options...
