jaekl Posted March 12, 2010 Posted March 12, 2010 After 23 1/2 years my clutch slave started to leak on my 86 2.5l. I replace the internal on on my 88 a couple of years back and thought this one would be a piece of cake. It ended up not being bad at all, but reaching the upper bolt looked like a show stopper. I ended up reaching over the top of the trans with a combination wrench. However, the wrench can not be rotated enough to get another notch, so I had to alternate with a different wrench. Luckily, they were not overly tight. Is there another way to remove the slave without removing the trans, of course? Thanks
-600JeepMJ Posted March 12, 2010 Posted March 12, 2010 one way is get a very long extension and universal joint. or you could do what I did.
Backroads Posted March 12, 2010 Posted March 12, 2010 is it just the 2 nuts you see there that need removed? then bleed the line through th bleeder I see? almost would be worth it to cut a little trapdoor out!
