Kenosha Warrior Posted February 24, 2010 Share Posted February 24, 2010 So I got stuck. Royally stuck. Blamed it on the CAD. Turns out I owe it an apology. My case isn't shifting into 4x4. It is adjusted properly (linkage) and goes into low range as it should, just no front output drive. I put the front end up on stands and with the lever in 4hi, I can turn the tires and watch the front d/s spin. Argh! Removal of the vacuum switch at the back lets me feel the shift rod moving properly, moves as if it is shifting into 4x4, but no front drive. Any suggestions to my WTF situation? Definately something internal as I did shim the CAD fork and observed the front driveshaft spinning with the CAD fork and plate removed. Link to comment Share on other sites More sharing options...
Geonovast Posted February 24, 2010 Share Posted February 24, 2010 I would say either the shift collar to engage the chain is shot, the bolt on the shaft for it broke, or your chain snapped. Regardless of what it is, you won't be able to fix it without removing the T-case. You'll probably be better off pull the T-case and cracking it open. Link to comment Share on other sites More sharing options...
beaterjeep Posted February 24, 2010 Share Posted February 24, 2010 Sounds familiar to me. My XJ is like that too, except on occasion 4lo will actually work, and I don't have the CAD locked yet. So, with that in mind, I can't help you, as I have no clue either. :fool: Link to comment Share on other sites More sharing options...
Kenosha Warrior Posted February 24, 2010 Author Share Posted February 24, 2010 The case is coming out within the next few weeks anyhow, 'nother one going in with the 5spd. Would've imagined the chain going would have mad a helluva racket Link to comment Share on other sites More sharing options...
