Oizarod115 Posted February 18, 2010 Share Posted February 18, 2010 :huh???: I have in my possession an unknown year internal slaw ax15 from a yj that was behind a 4.2. I intend on putting this behind a 97 4.0L and was wondering if anyone knows how I can determine up front what pilot bushig will fit or tell me what the measurements are so I can check it with a micrometer. Thanks all, Nick Link to comment Share on other sites More sharing options...
Geonovast Posted February 18, 2010 Share Posted February 18, 2010 If you have a micrometer... why not just check the tip of the input shaft on your trans? Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 18, 2010 Author Share Posted February 18, 2010 If you have a micrometer... why not just check the tip of the input shaft on your trans? well i will, just wondering if anyone knows what the normal ax15 pilot bushing measurements are Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 18, 2010 Share Posted February 18, 2010 1/2", is what the 87-90 are. 91+ should be .750 or 3/4" Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 18, 2010 Author Share Posted February 18, 2010 1/2", is what the 87-90 are. 91+ should be .750 or 3/4" thanks! thats the info i was needin... should be an obvious difference too Link to comment Share on other sites More sharing options...
JeepcoMJ Posted February 18, 2010 Share Posted February 18, 2010 yep yep...I just put a 93 trans into a 90, so I had to make a pilot that measured 3/4" ID, with the proper 1 and 1/16" OD. the OD is bigger in 91, I think. Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 18, 2010 Author Share Posted February 18, 2010 yep yep...I just put a 93 trans into a 90, so I had to make a pilot that measured 3/4" ID, with the proper 1 and 1/16" OD. the OD is bigger in 91, I think. i'll get the measurement on that tomorrow and put it in this thread so it'll come up in searches and all be in one spot maybe ;) i have known year motors lying around just don't know the year on that tranny. Link to comment Share on other sites More sharing options...
