ahmincha Posted February 14, 2010 Share Posted February 14, 2010 Hi everyone I have a 86 comanche 2.5 i redid all vacuum lines and decided to ck egr valve. So i hooked up a mighty vac to it and there was no change so i removed the egr valve hooked up again and it did not move or allow the gauge to build vacuum. So i bought a new one hooked it up to the mighty vac off truck same as old one no movement won't build vac am i missing something shouldn't apply a vacuum gauge to the egr make it move. Also its 4 wheel drive there is a blue vacuum line that goes underneath does it get hooked uo in engine compartment and where thanks in advance Link to comment Share on other sites More sharing options...
Wildman Posted February 14, 2010 Share Posted February 14, 2010 I really don't know 2.5's :oops: But......there is also the EGR Solenoid on the drivers fender. Check this page out, about 1/2 way down is the test for the EGR - http://www.lunghd.com/Tech_Articles/Eng ... ostics.htm That Blue vacuum line you mention........that the "supply" for the transfer case 4wd switch, it hooks up on the right side of the engine, near the charcoal canister, there is a Tee there, and the other run goes to the vacuum reserve in the right front bumper. Link to comment Share on other sites More sharing options...
ahmincha Posted February 15, 2010 Author Share Posted February 15, 2010 Well i found out 86 2.5 have positive pressure egr valves to ck them they must be on vehical unless you have a special tool. you need to bring engine up to 2000 rpms and see if egr valve moves. As for the blue vacuum line it is a vent the red is the vacuum supply Link to comment Share on other sites More sharing options...
