3WD?
You're not too familar with the inner workings off an open differential are ya?
Yes, the inner shaft would spin the correct direction, but neither wheel would actually receive power if it were to need it. If you removed your rear driveshaft, left the CAD unlocked, put it in 4wd, and tried to drive away, you wouldn't go anywhere.
The spider gears would just cause the inner shaft to spin. The R&P would be spinning, 3 of the 4 spiders, and the inner shaft. That's it.
Ya when you put it in 4 wheel drive the front carrier will spin but the spider gears will allow the disconnected shaft to spin and not the drivers tire. Like they said unless you have a locker type in the front there will be no movement from the front tires. torque goes toward the path of least resistance. in this case the shaft that doesnt have a tire attached to it would get everything and the drivers shaft would get none.
Nope... LSD (Limited Slip Differential) is what allows you to still power both when one has much less resistance than the other. It can still act like an open if there's a lot less resistance to one side. That's why when the clutch packs in the LSD wear out, it acts like a regular open diff.
