long box and cab sides needed in michigan
green_miner
I just bought a 1986 jeep comanche XLS with a 2.5 and a 5 speed transmission. The box is shot on it and both cab sides up to the body lines are bad. The front drivers side axle shaft is bad so i need a replacement for that too. I need a full box and if someone wants has cab sides ill buy those as well. I would also be interested in a parts truck for the right price. I live in Holland Michigan which is about 20 miles south of Grand Rapids. Any suggestions would also be appriciated. I use a mobil device so these type of things don't usually work but i can be reached at tron_2_rules@hotmail.com
  • 1 month later...
I've got an 87 with the 2.5L, 5-speed, 4x4, posted for $500. And an 86 with the 2.5L, 5-speed, 2x4, posted for $300. Both are located in Michigan, and both have rust problems around the wheel wells, but could make a good parts truck for you. Check the link if interested, there is a link in it for a bunch of pictures.
viewtopic.php?f=24&t=19835
