Are Renix gauge sending untis the same as 'HO"?
He's putting a 92 cluster into a 92. He's asking about stealing the sending units off an 88 for the 92.
You can't just put an HO cluster into a Renix... the entire system's different. The Fuel gauge polarity problem stems from needing a new fuel pump sender... when 91-92 MJ fuel senders are rather rare.
Right^^^^
HO cluster into an HO jeep
so only the oil presure sender will work.....That's fine, as that's the one that costs $30 the temp sender is like $10
