kar120c Posted January 24, 2010 Share Posted January 24, 2010 We are now into rainy season here in Oregon. Rain 25 hrs per day. Anyways there is about 3 inches of standing water in the cab and I've found the leak. Front right corner of the foot-well behind the plastic interior trim. I suspect the windshield since both the drivers / pass side is flooded. Is there any sort of seal where the quarter panel meets the A-frame & hood? Need to replace the rear window seal too since there is water back there too. Really frustrating since I kept the car covered with a brand new tarp. Whole jeep is bone dry including bed except for inside the cab. :fs1: Oh and I've done side windows before but never a front windshield. Any special tools I need and how hard is the job? Will be nice when I get my garage put back together. I just moved and now have a large two-car garage at my disposable. For now the jeep is just sitting outside drowning... :roll: Link to comment Share on other sites More sharing options...
DJM/78 Posted January 25, 2010 Share Posted January 25, 2010 If its is coming from the windshield , than you need a couple of things . 1, Good urethane sealant , pref. from glass shop . 2, Urethane pinch weld primer . 3, A cold knife , yes its a special tool . 4, New plastic clips that the windshield trim holds on to , if you don't break them cutting out the glass . 5, Probably a new windshield . 6, A long knife, another special tool . 7, A good sharp flat chisel or strong scraper . thin as possible . 8, A good caulking gun . stronger the better . That urethane is tough stuff. Its not impossible to save the old windshield , just very hard . The hardest part are the corners and the bottom , at the cowl . It does take some patience . I can help you more if you need it . What is your exp. with windshields . Its not an easy task if you don't know what your doing . You can cut up your headliner real easy if your not careful . Like the hacks who did mine . :rant: I can go step by step if you want . :thumbsup: Let me know . Link to comment Share on other sites More sharing options...
