Heater/AC panel vac hoses
The PO (or PO/PO) installed (then removed) an aftermarket radio and cut those little bitty vacuum hoses behind the heater/AC panel.
  • First question: Are there splices available to repair the cut ones?
    Second question: If not, does anyone have something laying around?
    Third question: It looked like part of the V-Switch was "jumpered", factory or possibly by the same PO, so is there someplace I can look to tell me where each of the colored hoses plug into?
PlumCrazy- First, welcome to the form :D
the simple repair to vac lines cut/broke are using Heat Strink tube, sliped over the cut lines and well, heat fitted.
I can't help you on the wiring, I don't have the shop manuals for this, others do and might chim in on that.
If you don't have a Chilton's or Hayes book, pick one up, and alot of info will get you started in the right direction. I like Hayes over the other.
