SuperWade2 Posted December 26, 2009 Share Posted December 26, 2009 I picked up a full console in nice shape today from a Cash for Clunkers 1997 Cherokee Sprot at the PnP (got a good deal too)... I wanted to see what kind of heartache I'd be looking at to install on my MJ without also swapping the dash and everything. (I also took the rear mounting bracket) Link to comment Share on other sites More sharing options...
Boilermaker Posted December 27, 2009 Share Posted December 27, 2009 This swap in the thread was done in an XJ but the process should be similar in an MJ: http://naxja.org/forum/showthread.php?t=63809 I thought there was a better write up on Naxja, but i couldn't find it. Link to comment Share on other sites More sharing options...
SuperWade2 Posted December 27, 2009 Author Share Posted December 27, 2009 This swap in the thread was done in an XJ but the process should be similar in an MJ:http://naxja.org/forum/showthread.php?t=63809 I thought there was a better write up on Naxja, but i couldn't find it. Thanks, doesn't look too bad... no ebrake to move. I think it only cost me $16 for the whole console with shiftboot and mounting stuff, so I'm not out that much if it doesn't work out. I also picked up an MJ Full Console Black Instert (with the eBrake slot blocked out) that I could move over to my existing XJ console if the other one doesn't work out. Wade Link to comment Share on other sites More sharing options...
SuperWade2 Posted December 29, 2009 Author Share Posted December 29, 2009 Doing a little test fitting now... I think the back will be OK...and the screw by the T-Case handle matches, up, but on the right side of the Stick, there is nothing to bolt it up too...might have to try to fab up something (that I'm HORRIBLE at). There will be a gap up front, but not sure how much that will bother me... I guess I'll see... Link to comment Share on other sites More sharing options...
