wheelin'cj5 Posted December 20, 2009 Posted December 20, 2009 Has anyone put a front grill with the quad headlights from an 87 wagoneer on an mj? If so any pics.I have everything to install them,wondering what ya think.
freakjeep93 Posted December 21, 2009 Posted December 21, 2009 yea a guy by the name of waggy has done it, dasbulliswagon did it and i know a guy on another forum that did it.
dasbulliwagen Posted December 21, 2009 Posted December 21, 2009 It was a fairly easy job, the wiring was plug and play, but the header panel bolt up was different than the MJ's. I think one of them had the bolt up studs on the fenders, and the other had the bolt up studs on the header. If yours are on the header like mine was, youll have to remove the studs on the fender and drill one of them out to bolt up the header, the other hole was already there. But if both of your bolt up the same, you are good to go. Fairly easy job... good luck! Here are the before pics,
wheelin'cj5 Posted December 21, 2009 Author Posted December 21, 2009 Thanks for the reply's and the pic's :thumbsup:
