JeepcoMJ Posted December 13, 2009 Share Posted December 13, 2009 I have an ax15 off of a '93 xj, and one off of a '95 yj. I have both clutches and both flywheels plus complete hydraulic systems that are already bled out. I'm wondering if I can use the high output clutch and pressure plate on the renix flywheel? I'd think that I should be able to... This is just a random question. I don't have a renix flywheel so I can't compare them Thanks, Pat Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 13, 2009 Share Posted December 13, 2009 As long as you keep Renix flywheel on Renix engine,you can use either clutch. Renix and HO flywheels are different, they send different signals for the different engine computers. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted December 13, 2009 Author Share Posted December 13, 2009 As long as you keep Renix flywheel on Renix engine,you can use either clutch.Renix and HO flywheels are different, they send different signals for the different engine computers. I'm aware that they're different, was just checking that I can use the clutch with either. Link to comment Share on other sites More sharing options...
HKB3 Posted December 13, 2009 Share Posted December 13, 2009 yes you can use the clutch but you will need a pilot bearing for a 70`s CJ with a 304 to use the AX-15(newer) on a renix motor Link to comment Share on other sites More sharing options...
