AMAZING DISCOVERY at the JY today(Part II)
mfpdm
Try this link for the light.
http://www.roverparts.com/Nxt/search.as ... s%2FLenses
It's easy once you know what to look for, comes from several different years jamminz.gif, and 38.00 a piece not to bad
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :hmm:
Ok - so they're not from a land rover or a porsche. But they are a direct, snap-in fit and can be turned off and on just like the OEM, are three wire, and (best of all) they cost 8.95 each.
http://www.infiniteinnovations.com/main.asp?p=4_179
Look at the third one down. I ordered a pair for each truck and they fit perfectly. They even came with new bulbs!
Yeah, up a couple of post I put the price of them just forgot to put the link. :thumbsup:
Also linked to those on the first page. However from that link, he said he had to elongate the hole a little to make them fit. :dunno:
The Point that I'm trying to make is to have a light that you don't have to alter the hole, easy to replace, cost very little, and work better than the stock ones. Each one of the lights that I have found cost me a $1.97 a piece from the JY. I like the Land Rover ones because they are just the lens without any trim and have a regular bulb that's easy to replace. I like the Taurus ones because they are easily found and the trim lays flat enough and can be painted to match the color I want. Best of all, these are Cheap! This is no way the only replacements out there just easy JY finds that fit right in the hole as it came from the factory.
:cheers:
