Gr8plainsDriftr Posted November 23, 2009 Share Posted November 23, 2009 Is this right? I was looking on Ebay, for an ax-15, and one of the vendors had one without the bell housing. Listed for 90-up wrangler, and 88 up toyota. is this right? or could i get some clarification Link to comment Share on other sites More sharing options...
Eagle Posted November 23, 2009 Share Posted November 23, 2009 The AX-15 is (was) made by Aisin-Seiki in Japan, and I believe it was also used in some Toyotas. Whether or not the Jeep version and Toyota version are 100% interchangeable I don't have a clue. Link to comment Share on other sites More sharing options...
WBKrazy Posted November 23, 2009 Share Posted November 23, 2009 not 100% sure, but didnt some 3.9 dakotas have the ax-15 as well? the bellhousing would definitely be different, and maybe the gear ratios as well... Link to comment Share on other sites More sharing options...
Oizarod115 Posted November 23, 2009 Share Posted November 23, 2009 not 100% sure, but didnt some 3.9 dakotas have the ax-15 as well? the bellhousing would definitely be different, and maybe the gear ratios as well... yes on the dakota, not sure on the toyota. Link to comment Share on other sites More sharing options...
comanche09 Posted November 23, 2009 Share Posted November 23, 2009 Check here: http://www.jeeps-offroad.com/f41/engine-swap-bellhousings-4740/ Link to comment Share on other sites More sharing options...
Gr8plainsDriftr Posted November 25, 2009 Author Share Posted November 25, 2009 wow thanks comanche09! good find. My Brother in law has a toyota 5 speed here, but its from a 80s pick up... looks like it has the short shaft, maybe an up grade on down the road... as id have to have the parts from an ax-15 to hook up to my h.o., then it seems you can twin stick it as well, idk i just took a quick skim over the thread, but it is book marked Link to comment Share on other sites More sharing options...
