Akula69 Posted November 20, 2009 Share Posted November 20, 2009 Awhile back Hornbrod had posted a 'how-to' in changing out the pre-96 washer bottle for a 96-plus XJ washer bottle that sits inside the fender. I am trying to figure out the wiring for that mod now. I have been slowly working my way through a 89 XJ engine bay wiring harness (cleaning, checking and repairing) and have gotten all the way around to the washer bottle. I believe I have the power leads for the two pumps (even though I will only be using the leads for the front pump I will wire the other pump as well for a spare), I do not have a 96 or later wiring diagram that shows the color codes for the fluid level sensor. I suspect wiring it backwards would make the indicator illuminate all the time, so I'd like someone with that knowledge to chime in :D The old 89 harness has three plugs: washer pump front: violet with white tracer/black (ground) washer pump rear: violet with orange tracer/black (ground) fluid level sensor: violet with white tracer/white with black tracer On the 96/97 model it is: washer pump front: black with white tracer/black (ground) washer pump rear: black with white tracer/black (ground) fluid level sensor: ? Any assistance is greatly appreciated. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 20, 2009 Share Posted November 20, 2009 Shoot me an email with your email address and I'll send you the schematic how I wired my 91. Link to comment Share on other sites More sharing options...
