I have an 88 MJ that has window scrapers that look like they were made of Graham crackers. I have some replacements but am not sure of the proper (easiest) way to replace them. Any help?
Thanks
Al
Roll the window down. The "wipes" are held in with metal clips inside the door frame. I just grabbed mine and pulled up.
What did you pull up? I see the clips 3 to a side Do I pull up the clips or what/
Thanks
Al
If I remember from when i did mine, just roll the window down and pull up on the wipe. The clips will stay in place on the door. Then the new clip just slides back in.
