I've almost completed my zj disc brake conversion in a 87 mj d44. It is pretty easy and I'll bet alot cheaper than teraflex kit. You just have to redrill the parts to the different pattern and machine out a little in the center of the brackets. And you will need an axle retainer plate from a dana 44 tj or a custom spacer to get the bearing preload. Not sure about a dana 35 but it should be the same as long as its a non c clip. If it a c clip axle it should be a direct bolt in but I'm not sure about that. I got my complete zj d35 with disc brakes for 100 bucks. After putting new pads rotors and and parking shoes I'll estimate 200 bucks for conversion.http://www.pirate4x4.com/tech/billavist ... index.html
This link should help. I looked up a picture of the tera flex kit and it looks identicle to zj rear disc brakes for $499
