Axle Quuuziees
Unless by good fitting, you mean 9", or so wider than stock,
there's no factory 60 near the stock width.
Only 60's near our 60"ish width would be out of something weird, like construction equipment/man lift, etc, tho then you have other issues, like lack of brakes/closed knuckles/weird bolt patturns/centered diff, etc, etc.
If you want full width (~69" wide), the 78-79 Ford D60's are the most XJ/MJ/TJ friendly:
the short side is fairly long, so there's plenty of room for the coil bucket.
Later Fords have shorter 'short sides' (better choices if you want to narrow it, but not much room for the coil bucket on the drivers side).
Some have claimed it's tough to build a usable D60 for us under 63", or so.
I never tried, but would look to building a 9"/D60 hybrid if I wanted to stay near stock width.
FWIW, even later Fords have ball joints (instead of king pins), and unit bearings, good, or bad depending on what you're looking for.
Chevy & Dodge D60's are passenger drop (and low pinion), and don't work for us unless you get a pass drop T-case & move the exhaust (if you're keeping the 4.0L)
I should add, if I were building something with a full size Diesel engine, I would defiantly put a D60 underneath it upfront.......
but, to be honest, I'd probably build the whole thing around something other than a uni-frame MJ.
A nice flat fender Jeep pickup cab, on a 76+ FSJ frame would be a good place to start. :smart:
Well, after looking up after market axles I've decided to go with a donor F250 78-79 ford! Later when I get rich I might build one frame up with the perfect parts.
Can anyone link me some pics of trucks using the 78-79 F250 drive train?
I want to know my lift options and how it's going to set.
TY~~!! :thumbsup:
It's going to be pretty straightforward. Trim off the leaf perches and weld on a control arm bracket kit from one of the aftermarket sources (don't bother with stock MJ brackets, get the stronger stuff). The axles should be about the same width as mine.
Sno-Fighter truck, :idea: anyone ever heard of it? Aparently it's a special model of a F250 or something that fits one that came stock with a Dana60 front end. Here's a picture of the D60 on a 1978 F250
Sry... haven't figured out how to post pics yet
Will this axle fit on my comanche's front end?!?!?!?
Pretty much the same amount of effort. the snowfighter 60 is the same 60 found in the F-350s. Be prepared, the Dana 60 is a heavy mutha. 500 pounds or so.
Are you saying that 500 pounds is to much? I'll be getting the D60 from the F250 and it weights the same? Are you saying that I should possibly go with lighter axles for my truck? What are some of the weights of the axles like
D60 F350 front= 500 lbs
D44 F250 front= ___
D60 F250 rear= ___
Ford 9" rear= ___
btw,
Thank you very much for all the help, I've been learning a lot with this forum and I'm glad to have helpful people willing to give their time to help me with my new hobbie.
