xmeatbagx Posted October 31, 2009 Share Posted October 31, 2009 I know this has been explained alot but can someone show me pictures of what you have to change to put in full guages and where they go? Where are the sensors? :grrrr: I hate my idiot speedo and want a real temp guage... and a tach. Sorry for being a pain. Thanks, Sean Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted October 31, 2009 Share Posted October 31, 2009 Its different for different years. If your asking about the '88 in your sig. Check out mu build. My '89 should be the same as yours. I have pictures and explanations. CW Link to comment Share on other sites More sharing options...
JeepinSoldier Posted November 1, 2009 Share Posted November 1, 2009 I just did this mod. You will have to change both the oil and temperature switches to sender units. The oil switch/sender is near the oil filter and the coolant temp is on the driver side of the engine tward the rear next to the valve cover. An extensive writeup on the swap with lots of pix and the exact part numbers for the sending units that you need to get is on the NAXJA website here: http://www.naxja.org/forum/showthread.php?t=921205 It even shows you how to reset the odometer to match your trucks actual miles! :thumbsup: Be careful when removing the speedometer cable from the rear of the cluster in your truck - it breaks easy and then you will have to pull another one at the JY when you pick up the full cluster. Also - 86-90 (Renix) clusters are diffrent from 91-96 (HO) For the least problems get a cluster from the same year and engine (4 or 6 cyl) in your truck. Link to comment Share on other sites More sharing options...
