rafiki Posted October 26, 2009 Share Posted October 26, 2009 The problem that I'm having is that the truck does not start. The truck is being sitting for about 3-4 years, recently about three months ago the fuel pump was replaced and the oil filter o-ring kit, by a mechanic that works for a guy that owned me money of some design work that i did for him, he told me that the fuel pump was replaced but i don't know really it is really hard to start the truck, even if i'm jump start the truck, it takes a while. So started reading about this issue and found that it could be the CPS, so i replaced, for a new from autozone. After i replaced the truck did not started , check the ground connection form the battery and found that there was a voltage drop of approx 3 volts so i clean all the terminals and now i don't have a voltage drop. I want to perform a fuel pressure test could you guys point me in the right direction. Also, where can i get the ballast resistor is broken. Finally is there any local comanche owners? Thank you for help. Link to comment Share on other sites More sharing options...
Geonovast Posted October 26, 2009 Share Posted October 26, 2009 There's a little zerk on the fuel rail. Remove the cap, and screw a fuel pressure tester onto it. Then have someone try to start it. It should read about 40 psi, and it should hold it after you shut the key off. Link to comment Share on other sites More sharing options...
veritas4156 Posted October 26, 2009 Share Posted October 26, 2009 It doesn't have to hold that pressure 100% after you shut it down, but it shouldn't go down below 18 psi or so after about 20 minutes. it should remain there till the next time it is started. Link to comment Share on other sites More sharing options...
jbhill Posted October 26, 2009 Share Posted October 26, 2009 ballast resistor sounds like the problem to me. I'm pretty sure u can buy a new one, or scrounge one off of an XJ in the jyard. there is a few of us in GA. Link to comment Share on other sites More sharing options...
mjeff87 Posted October 26, 2009 Share Posted October 26, 2009 or you could eliminate the ballast resistor entirely.....the only reason it's there is to quiet the pump a bit. Just splice the wires together. Jeff Link to comment Share on other sites More sharing options...
navigator Posted October 26, 2009 Share Posted October 26, 2009 when I first got my MJ, I had a hard time cranking it but I figured out a trick that works for mine. turn the key to on but not to crank, you can hear the fuel pump come on, after a couple seconds you hear it turn off (or so it sounds that way). I then try to start it and hold the accel to the floor and it turns over a few times and starts right up. if i vary the process it takes longer to crank. i know there are likely some fuel flow/pressure issues but it starts fine and i just haven't checked into them yet. Link to comment Share on other sites More sharing options...
rafiki Posted October 27, 2009 Author Share Posted October 27, 2009 Well, i just did a fuel pressure test and i got 34psi, it held the pressure, after approx 20min the pressure drop to about 30 psi. I switch the fuel pump relay with the ac relay to see if that was the problem but it did not made a difference also i jumped the ballast resistor but did not a make a difference, what I'm thinking is to empty the fuel tank and put some fresh fuel. Any ideas? Link to comment Share on other sites More sharing options...
Geonovast Posted October 27, 2009 Share Posted October 27, 2009 You didn't replace the fuel? Well, there's the problem. Link to comment Share on other sites More sharing options...
rafiki Posted October 27, 2009 Author Share Posted October 27, 2009 Any ideas where can i dispose the old fuel? Link to comment Share on other sites More sharing options...
Geonovast Posted October 27, 2009 Share Posted October 27, 2009 Dump it into a clean container, put a little Stabil in it, and just add a small amount to your truck when you fill up. Link to comment Share on other sites More sharing options...
rafiki Posted November 8, 2009 Author Share Posted November 8, 2009 Finally i dropped the fuel tank to see what the hell whats going on with the fuel pump and the tank is rusted from the inside really bad, and the fuel pump assembly is in really bad shape, i was reading that a radiator shop could clean the tank, but i figure if i can get a new one for less than $150 it might be worth buying a new one, i read that a good place is rockauto or ebay , but what about the fuel pump assembly in rock auto cost $330 where you guys think i can get a better deal? I will post a picture of the pump so you guys give an advice. Thank for your help. Link to comment Share on other sites More sharing options...
