'98 A/C on '88?
you may need to figure out something with the heater controls since you'd have to replace the heater core/evaporator, and you may need to grab the compressor bracket off the engine also. i'm not sure, just things to consider.
i think he's correct that the engine bracket is different for it, which also means the other accessories may mount differently as well. just compare it realll good so you get everything
