Comanche86 Posted October 13, 2009 Posted October 13, 2009 What size are the bolts that hold the chrome trim onto the fiberglass piece above the grill.(I don't know the technical name.)
Automan2164 Posted October 13, 2009 Posted October 13, 2009 Although I am unsure becasue its been so long, but the most common sizes up there are 8mm, 10mm, 13mm, and although I doubt it, 15mm. Rob L.
Pete M Posted October 13, 2009 Posted October 13, 2009 Are you looking to replace the bolts? the nuts? or the size of the wrench that would remove them?
Comanche86 Posted October 13, 2009 Author Posted October 13, 2009 I pulled the chrome trim off(8mm) because i thought there was bolts behind it that held the inner grill assembly in( I was wrong) but i got the inner assembly out finally to make pulling the motor a little easier.
