87MJJeep Posted October 11, 2009 Share Posted October 11, 2009 I have my windshield molding off while hunting for my water leaks. I used a little chrome polish on them, and they shined a little bit better. Judging by the surface condition, do I need to rough up the surface any before painting them black? Use steel wool for that? I like the look of jpdocdave's semi-gloss black trim, so I'll go with that black. If anyone has any paint brands to recommend, let me know. A year ago or so I repainted the grill with DupliColor's trim black. It's held up well. Here's what mine look like now. Link to comment Share on other sites More sharing options...
oldrusty Posted October 11, 2009 Share Posted October 11, 2009 I like the look of dupli color semi gloss black myself. Has a little sheen to it compared to flat black but isnt glossy. Link to comment Share on other sites More sharing options...
Frankdm83 Posted October 12, 2009 Share Posted October 12, 2009 Go with SEM trim black, it matches most OEM black trim Link to comment Share on other sites More sharing options...
87MJJeep Posted October 12, 2009 Author Share Posted October 12, 2009 What stores carry SEM? Did you guys repaint ones that were already painted, or did you paint polished pieces? Link to comment Share on other sites More sharing options...
jbhill Posted October 12, 2009 Share Posted October 12, 2009 i would scuff it with a grey scotch bright, clean it good with some rubbing alcohol, then spray on some 1k etching primer, then the SEM trim black. since it is aluminum. Link to comment Share on other sites More sharing options...
87MJJeep Posted October 12, 2009 Author Share Posted October 12, 2009 i would scuff it with a grey scotch bright, clean it good with some rubbing alcohol, then spray on some 1k etching primer, then the SEM trim black. since it is aluminum. Thanks for the advice! Link to comment Share on other sites More sharing options...
