JOMJ87 Posted September 5, 2006 Share Posted September 5, 2006 Anyone have any better instructions for pulling my steering column out or even getting to ALL i mean ALL of the electrical guts to replace them. I have a huge wire issue on the inside of mine So its time to fix it before it starts a fire. Any help would be great. Cole Link to comment Share on other sites More sharing options...
BRC 88MJ Posted September 5, 2006 Share Posted September 5, 2006 These are just from memory as it's been a while since I pulled my column but I'll try to help: -Remove the lower valance from the dash -Remove two bolts attaching column to firewall -Disconnect the steering coupler between steering box and column in engine bay -Remove two bolts attaching column to dash mount (this should allow your column to droop far enough to disconnect the wiring) -Pull column after disconnecting electrical Note: If you have a column shifter, disconnect all of the associated linkages involved with it. I can't help you much with that, though. Link to comment Share on other sites More sharing options...
JOMJ87 Posted September 5, 2006 Author Share Posted September 5, 2006 Disconnect the steering coupler between steering box and column in engine bay I seen the 2 metal rods that are for the key release and all but i don't know if this is where it goes or not. When i pulled the column out of a cherokee i just cut the rods cause i was in a hurry and know i am regretting it. I had tried to remove them but got tired of messing with it. I know they run up to the key but how can i get to them i tried to do it but the plastic that surounds the column wasnt coming off is there a trick to it. Hope this helps find my answer i don't think i was thorough enough with my initial question. Thanks Cole Link to comment Share on other sites More sharing options...
