97+ door swap
i swaped my lock cylinder over, i had to use the retaining clip out of the new door and flip it around. most people use the stock hole for the factory latch, but mine didnt quite line up like that.i also drilled out the 4 or 5 welds that hold that sticker plate out. i used the stock XJ bolts with nuts and big fenderwashers.
[edit] sorry, ill try to get a blurrier pic...lol
When I did mine, the lock cylinders from the new door and the old door had different diameters. So I couldn't use the older cylinders. I took the new cylinders out and had them redone to match my ignition key. Cost $7 at the locksmith who hangs out at the local Pick-A-Part parking lot.
