Need answer quick! windshield wiper motor, what years compat
well I pulled the motor out of an 87, just the motor because the arm structure was broken. then I looked around and found a 99 Cherokee and looked at the windshield Assembly and saw that the only obvious difference was the plug so I cut a length of wire off after the plug and will wire it in.
I also scored an air box top because the PO put in a sweet sub pump i mean a sweet cone filter. and got a slightly damaged 99 header panel assembly. the slightly damaged for 75 bucks was a much better deal then the newer undamaged on for 300 bucks.
