oregonman Posted August 22, 2009 Share Posted August 22, 2009 k guys i have a question. i'm running 4 36.12.50.15s mickey Thomson baja belted but one is almost bald. so i seen a one 36" tire on Craiglist for $100 its a 36.12.50.15 super swamper tsl brand new with the little pokes still on it.but its about inch taller then the bald tire. the guy @ les schwab would not install the tire because it could cause my drive line to bind up?? but then he said if i wanted to bring just the tire in he would put in on the wheel for me so he would not be responsible for any damage that might happen ;...... so my question is if i run this tire that is a little bit taller the then other side on the rear axle , will complete destruction happen ? :huh???: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 22, 2009 Share Posted August 22, 2009 If your running an open diff, no nothing will happen. Now having said that, its always best to replace both tires on an axle. If your running a locker, DO NOT DO IT!!! If your running a LS factory or not it will cause accelerated wear and will not be good for the LS unit. CW Link to comment Share on other sites More sharing options...
Pete M Posted August 23, 2009 Share Posted August 23, 2009 I would probably buy it and work on getting another TSL to match and then run them in the rear and use the odd man out Mickey to use as a spare. I've got 33" trXus up front and run 33" boggers in the back and have not experienced any issues that I could link to the different types of tires. I only use 4wd in the dirt/mud/sand. I don't advise trying to use the TSLs on the street. :ack: Link to comment Share on other sites More sharing options...
oregonman Posted August 23, 2009 Author Share Posted August 23, 2009 ight thanks guys i will buy another tsl. and have 2 MT spares . thanks for they advice. Link to comment Share on other sites More sharing options...
