sufidancer Posted August 21, 2009 Posted August 21, 2009 Hello fellow MJ-ers, I finally got my MJ back on the road after a month of trying to find a torque converter. :headpop: I have a TF 904 3 speed automatic with a stock NP229 that is shot to hell Does anyone know if a Dana 300 bolt up ok with a TF904 automatic? The Dana is 23 spline and the stock 229 is 23 spline. But I was wondering if there are any issues with getting a Dana 300 TC to fit my truck.
reson46 Posted August 21, 2009 Posted August 21, 2009 Yes, the D300 shares the same round bolt pattern as the NP transfer cases. You do realize the D300 has a passenger side front output? Unless you flip it or swap in a matching front axle it will not work in an MJ. Willy
sufidancer Posted August 22, 2009 Author Posted August 22, 2009 Thanks for the info and reply, I found the quandry after I pulled the trigger for a Dana 300. crap. Nothing is ever easy when you start switching $#!& around. :fs1: I am going to research a work around. A cheap work around if I can manage it. I seen a flip kit going for to much money. five hunnert is to much. Then there is the Novak flip ring. I will look into that...my luck that will be just as much. If anyone knows a tried and true way to flip a dana 300 feel free to pipe in. Thanks.
jpdocdave Posted August 22, 2009 Posted August 22, 2009 the d300 is one of the strongest t cases around, a couple are stronger, but also a lot bigger. its a great jeep t case. all cast iron, gear driven, and simple. you won't ever have a problem with it. it can be twin sticked also. if you are going to wheel with it you may wanna drop the dough on a 4:1 gear set. it is a hair higher gear than the np231. somewhere around 2.7:1 if i remember right. there are people that are flipping them without buying kits at all for next to no money. search the web you should be able to do it yourself.
