ncmountainMJ Posted August 14, 2009 Posted August 14, 2009 Ok for some odd reason now my 89 won't start. I dropped the fuel tank to remove the bed and thats when the trouble began. It will turn over and gets spark but the fuel pump won't come on. I hot wired the fuel pump and it is working. I checked the fuel pump relay and it comes on but then a few sec later it cuts off but the pump never comes on. Also after checking the wires at the relay I never get anything on the orange wire coming from the ECM. Is there any advice that you guys could give me as to what to check next... or mabey a bypass... any help would be appreciated!!
redneck23ms Posted August 14, 2009 Posted August 14, 2009 did you disconnect the ground wire behind the drivers side tail light? if so thats your problem. that is where the fuel pump grounds
Geonovast Posted August 14, 2009 Posted August 14, 2009 did you disconnect the ground wire behind the drivers side tail light? if so thats your problem. that is where the fuel pump grounds :agree:
HOrnbrod Posted August 15, 2009 Posted August 15, 2009 Also agree w. the above. But if the fuel pump ground is intact, check out these two threads - may help: http://www.comancheclub.com/forums/viewtopic.php?f=2&t=15819&p=159628&hilit=relay+fuel+pump#p159628 http://www.comancheclub.com/forums/viewtopic.php?f=2&t=6977&hilit=relay+fuel+pump
Donny88 Posted October 26, 2014 Posted October 26, 2014 I'm having the same issue. I will check the ground on mine tonight. if you figure it out pass it on I could use some help
