Transmission
an easy way to tell if its the puke goat is to crawl under the truck and look at it. if there is a seam in the tranny at the bottom running front to back where the 2 side halfs of the tranny bolt together then its the pukegoat. if there isn't a seam lengthwise then its an ax15
