buddy208 Posted August 3, 2009 Share Posted August 3, 2009 would axle fit from a 94 cherokee or do i have to modify them. cause my leaf springs are 42' across and 55 in length and the cherokee is 43.5' across and 49 in length Link to comment Share on other sites More sharing options...
88pioneer Posted August 3, 2009 Share Posted August 3, 2009 cherokee leafs are shorter than comanche leafs, and cherokees are spring over instead of spring under like the comanche. So you would either have to find another leaf from a comanche, or resort to buying a new one Link to comment Share on other sites More sharing options...
Automan2164 Posted August 3, 2009 Share Posted August 3, 2009 You HAVE to re-weld the perches. You can stretch them to somewhat bolt on, but don't even try. Rob L. Link to comment Share on other sites More sharing options...
buddy208 Posted August 3, 2009 Author Share Posted August 3, 2009 what about the shock mounts Link to comment Share on other sites More sharing options...
Pete M Posted August 3, 2009 Share Posted August 3, 2009 The comanche can't really use the XJ shock mounts (wrong location and orientation). You'll need to slice them off and add your own. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 3, 2009 Share Posted August 3, 2009 So to summarize, YES you can use the XJ axle in a MJ. You MUST have and weld on new perches. REGUARDLESS of orientation. (SUA/SOA) I recommend factory MOPAR perches. CHEAP and very stout!! You will have to chop off XJ shock mounts and add new mounts. Available from numerous suppliers. Rubicon express makes a nice "universal" mount. I have made a bunch for myself and a couple guys on here. I used a "HELP" rack mount and some scrap steel. Check out my build thread for pics and descriptions. As you have found XL and MJ leafs are different and not interchangeable. So keep/find a set from the MJ. GOOD LUCK!! CW Link to comment Share on other sites More sharing options...
