Speedo Cable
Junkyard, if you have one near you :D
Otherwise, most of the parts houses should have them, or be able to get them. Advance Auto lists them on their website for $11
http://www.partsamerica.com/ProductDeta ... 83&ptset=A
Be advised, there are two types of ends on the speedometer end. One is a metal end and one is plastic.....depending on year. They attach differently to the back of the cluster, so make sure you get the right one. And if you have cruise control, there is a small second cable that runs from the cluster to the main cable.
HTH,
Jeff
