front end vacume disconect ... ithink anyway?
hey guys I'm doing a 4wd conversion on my mj but i don't have a donor vehicle i bought a dana 30 front end and I'm wondering how to hook up what i think is a vacume disconect. its a hookup for some tipe of hose to the right of the diff when you are behind it. what i am wondering is either how to hook it up so that my front drive works or how to make my front end conected all the time. plese help!
-Pull the cover on the CAD (central axle disconnect)
-move collar over to lock axle shaft
-use one of the plethora of ideas for keeping it there
-re-install the cover
-remove the rats nest of vacuum lines and cap the start point
Done. :D Your Jeep will be set up just like the rest of modern Jeeps. 4wd is now available any time you pull the lever. No more problematic CAD.
