xComancheKidx Posted July 9, 2009 Share Posted July 9, 2009 every time i start the manche my 4x4 light is on and remains on while it is running even though i am not in 4 wheel drive...does anyone know what could possibly be causing this? Link to comment Share on other sites More sharing options...
LoTGoD Posted July 9, 2009 Share Posted July 9, 2009 Bad ground? Corroded plug connectors? Take the connector apart, clean the plug ends, and add some dielectric grease. If that doesn't fix it, I'm not sure what it could be. Link to comment Share on other sites More sharing options...
Geonovast Posted July 9, 2009 Share Posted July 9, 2009 Take the bulb out and forget it was ever there. You don't really need a light telling you that you're in 4wd, do ya? :dunno: Link to comment Share on other sites More sharing options...
LoTGoD Posted July 9, 2009 Share Posted July 9, 2009 Take the bulb out and forget it was ever there. You don't really need a light telling you that you're in 4wd, do ya? :dunno: When you get older you do...I'm forgetful. Link to comment Share on other sites More sharing options...
aemsee Posted July 9, 2009 Share Posted July 9, 2009 Take the bulb out and forget it was ever there. You don't really need a light telling you that you're in 4wd, do ya? :dunno: When you get older you do...I'm forgetful. But you will remember the first corner you take on a dry road. Link to comment Share on other sites More sharing options...
