Me: 1986 MJ 2.8 V6 2barrel carb with 228 selectrac. 3 speed auto TF904
Donor vehicle: 1995 YJ wrangler Inline 4 cylinder 3 speed automatic case stamped
361 . Transfer case is 207 command trac
My research for this vehicle shows that the 1995 YJ 4 banger did come with a TF904
but my concern is the donor has a plug in for what I think is a electronic torque converter.
My concern is whether or not I can work around this as my torque converter was non lockup.
Any one see where this donor transmission may cause me grief. Any input would be greatly appeciated.
Sounds like someone needs a 5 speed conversion. :thumbsup:
I hope not. I do not want to fool with master cylinders, pedal assemblys and shifters. to adapt. Someone in a forum mentioned running a hot link from the battery to a switch on down to the converter plug .
