vanschmidt Posted June 9, 2009 Share Posted June 9, 2009 :???: What is the procedure in replacing the pickup sensor in my 1988 4.0 automatic Comanche? I started the job but I thought that I'd better ask someone that has done this already before going any further. :dunce: Link to comment Share on other sites More sharing options...
Geonovast Posted June 9, 2009 Share Posted June 9, 2009 It's usually just a good idea to replace the whole distributor. They're not that expensive, and then you've got a new dis. I read over instructions for replacing the CMPS. Didn't look fun. Why, specifically, does it need to be replaced? Link to comment Share on other sites More sharing options...
vanschmidt Posted June 9, 2009 Author Share Posted June 9, 2009 :brows: Where are these instructions you speak of? Link to comment Share on other sites More sharing options...
Wildman Posted June 9, 2009 Share Posted June 9, 2009 here's the "test" and change out for the Cam Position sensor (ignition pickup)- http://www.lunghd.com/Tech_Articles/Eng ... Stator.htm Link to comment Share on other sites More sharing options...
vanschmidt Posted June 9, 2009 Author Share Posted June 9, 2009 Thank you Wildman, It was the link that I needed. :cheers: Link to comment Share on other sites More sharing options...
vanschmidt Posted June 9, 2009 Author Share Posted June 9, 2009 :driving: Just got done test driving my 1988 Comanche after replacing the distributor electronic pickup sensor. The procedure off the link Wildman sent was very easy to follow. :thumbsup: http://www.lunghd.com/Tech_Articles/Eng ... cement.htm Link to comment Share on other sites More sharing options...
