rear 4 link
As in a kit? Doubtful. Especially since the fuel tank would be in direct conflict for space with one of the upper links.
What's wrong with the leafs? Broken? Sagging?
add-a-leaf, spring over axle.
Pete to answer your question I think he's on stock suspension w/o lift with a 350 in it.
billybob In a couple weeks I'm tearing apart another comanche and should have a set of leafs left over.
you can also have your rear springs repaired. IIRC they can "re-coil" the eyes and temper them a bit to keep them from ovaling out again.
