Emergency brake pedal
Does anyone have a good pic of how the spring goes on. I was changing the front cable and it came off before I coulsd see where it went. It is the spring that holds the tension on the pedal so when you release it, it springs up
Glad to have helped but now I see I was talking about the wrong spring. :doh:
You wanted the one on the bottom. That one on the top engages the little rachet thingy to engage the lock for the pedal as you push it down. A guess a picture is indeed worth a thousand words. :thumbsup:
