brdhntr Posted May 21, 2009 Share Posted May 21, 2009 ok. i have a clunk in the steering that i need to fix. it's getting worse. this just showed up after i put some larger tires on (not "big" tires) 225 75 16. the clunk is only heard when you turn from the right to the "center" position. right when it hits center there is a clunk. it's not there when coming from the left to center. it happens when it's running or not. i guess maybe you can kind of feel it in the steering wheel, a little. so today i was checking it out and it's coming from the front of the truck, like the steering sector (gear). i can't find anything loose in the suspension, everything seams tight. would a bad sector do this? i've had sectors go and they usually wander or something, i've never had one that clunks. ideas? :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted May 21, 2009 Share Posted May 21, 2009 I'd watch under the front and have someone else turn the wheel back and forth. If you don't see anything loose under there, take a look through the top and watch the steering shaft and pitman while they turn, that should show you if there's anything wrong in the box itself. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 21, 2009 Share Posted May 21, 2009 I'd check the trackbar also, worn parts probably not showing themselves until larger tires were added. Larger tires = increased leverage and force on steering components. Link to comment Share on other sites More sharing options...
Geonovast Posted May 21, 2009 Share Posted May 21, 2009 Did you do an alignment after putting on the bigger tires? It's probably not much, but it will need an adjustment. Link to comment Share on other sites More sharing options...
brdhntr Posted May 22, 2009 Author Share Posted May 22, 2009 i have been under it while the steering wheel has been turned back and forth and can't see a thing. that's why i'm a bit puzzled. i thought i'd look under and find a loose tierod or something. :dunno: Link to comment Share on other sites More sharing options...
