bigalpha Posted May 14, 2009 Share Posted May 14, 2009 I assume the rubber wipers that clean your windows when they roll down are the same as on an XJ? I am also assuming all the weather stripping is the same as well? Most of my window/door rubber is in kind of bad shape, and wanted to verify my assumptions before I start looking. TIA. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 14, 2009 Share Posted May 14, 2009 Yep, same as the 96 and below 4-DR XJ front doors. Link to comment Share on other sites More sharing options...
bigalpha Posted May 14, 2009 Author Share Posted May 14, 2009 Yep, same as the 96 and below 4-DR XJ front doors. Awesome. Thanks. I know that with XJs, if you use 97+ door weather stripping in a 96- front doors, it will seal much better. Is this the case with the MJ, too? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 14, 2009 Share Posted May 14, 2009 Yes, for the outer weatherstrip. The window pieces are different though. Link to comment Share on other sites More sharing options...
bigalpha Posted May 14, 2009 Author Share Posted May 14, 2009 Yes, for the outer weatherstrip. The window pieces are different though. Right. Looks like I'll be hitting up PaP sometime to replace my rubber. Link to comment Share on other sites More sharing options...
smithe1811 Posted May 14, 2009 Share Posted May 14, 2009 Whasnt there a post someone made on where you could buy it new? quite some time ago if i recall correctly. Link to comment Share on other sites More sharing options...
