jeep_freek88 Posted May 11, 2009 Posted May 11, 2009 Ok so I still can't find a speedo cable for my truck .......... my question is can I put a xj gage cluster and speedo cable in my truck?? Or just swap the fitting on the back of the cluster for the cable or ............ any ideas please help ....... OH !!!!!!!!! I got my truck running !!!!!!!!!!!!!!!!!!!!! For the fist time in like 6 months ..... found a broken wire under the hood ....... little bugger .............. So i really need to figure out this speedo cable problem........... :help:
Automan2164 Posted May 11, 2009 Posted May 11, 2009 Yep, everything should be a direct swap. Just make sure its a renix era jeep if you haven't already been told. Rob L.
jeep_freek88 Posted May 11, 2009 Author Posted May 11, 2009 Ok What year xj should i get it from?? Or should i say what year xj has a 78inch cable? :cheers:
Automan2164 Posted May 11, 2009 Posted May 11, 2009 You can get any renix XJ/MJ from 87-90. Should all be the same. The HO in 91-up is a whole different electrical animal. Rob L.
jeep_freek88 Posted May 12, 2009 Author Posted May 12, 2009 Ok thanks for all the help.......My truck has the pukegoat trans if that makes any diff I don't know :???: :dunno: :cheers: thanks everyone
Geonovast Posted May 12, 2009 Posted May 12, 2009 Any 87-90 XJ/MJ 4.0 5 speed 4wd cable with the same cruise option will be identical to yours. An automatic cable should work(may be the same, I don't know) since the AW-4 is a little longer than the 5 speeds. And yup, 91+ doesn't have a speedo cable, it's all electrical.
