Can anyone tell me if there is a way to pull the input shaft out of the tc with out breaking it all the waydown.
The last person that rebuilt it must have used super glue on it with the gasket sealer :wall:
Any info is greatly appreciated as i can't afford to break anything at this point getting it brokedown.
Yah, you gotta split the case. I just swapped mine last week. FYI, there are 3 "slots" around the circumference of the case for you to put a screwdriver in to pry against. Also be aware that you have to remove the rear retainer and extension housing before the case will come apart.
Like I said, I just did this, I've never tore a TC apart before, it wasn't hard.
Cheyenne
thanks i was fearfull of breaking it after i pulled the bolts and it still didnt come apart.
Was hoping for an easy tear down :doh: but not this time.
