BJA814 Posted May 1, 2009 Share Posted May 1, 2009 I'm looking at buying a 4wd AW4 from a 97 xj. Will this work in my 1988 2wd AW4 4.0 MJ? I just need to know if I will run into any wiring troubles with it being newer. I can grab the whole trans wiring harness if that would make my life easier? Brad Link to comment Share on other sites More sharing options...
BJA814 Posted May 1, 2009 Author Share Posted May 1, 2009 Any body? I'd like to be sure before I cough up the cash for this thing on Sunday. Link to comment Share on other sites More sharing options...
reson46 Posted May 1, 2009 Share Posted May 1, 2009 The wiring is different on '97+ XJ AW4s. It will not plug in to the connectors from your '88. I don't know if you can swap over the sensors from the '88 to the '97. I don't think there would be any problem with the NSS, but I have no idea with the other wiring bundle. There also is no separate transmission computer, it is controlled by the ECU. This would prevent you from swapping over all the transmission electronics from the '97 to the '88. Willy Link to comment Share on other sites More sharing options...
maddzz1 Posted May 2, 2009 Share Posted May 2, 2009 Are you doing a 4WD conversion? The 2WD and 4WD trannys are different also. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 2, 2009 Share Posted May 2, 2009 Also the output spline counts are different among the early/later years. So if your converting to 4WD you'll need the transfer case along with the tranny and not[ an older (later than 1990) transfer case. Link to comment Share on other sites More sharing options...
BJA814 Posted May 2, 2009 Author Share Posted May 2, 2009 Thanks guys. I am doing the 4wd conversion, which is why I'm looking for a 4wd tranny. I have acess to several spare NP231s, with both spline counts. I was mostly concerned with the wiring. I just found a '96 tranny for $50, so I think I'll pick that up. Brad Link to comment Share on other sites More sharing options...
