grandpabear Posted April 25, 2009 Share Posted April 25, 2009 what was the stock tranny for the 87' MJ, I have the 5 speed. I'm looking for the gear ratios of it, and the gear ratio of the 231 transfer case,( I think it is 272 to 1 low range?) . with 4:56 gearing on 35' tires, I'm trying to figure out my crawl ratio is. Link to comment Share on other sites More sharing options...
Geonovast Posted April 25, 2009 Share Posted April 25, 2009 Which motor? If you have the 4.0, then your trans is a peugoet BA 10/5. 1 - 3.39 2 - 2.33 3 - 1.44 4 - 1 5 - 0.79 R - 3.25 If you have the 2.5, then you'll have an Aisin AX-5 1 - 3.93 2 - 2.33 3 - 1.45 4 - 1 5 - 0.85 R - 4.74 If you have the 4.0 your crawl ratio is 42.04:1 If you have the 2.5 your crawl ratio is 48.75:1 Link to comment Share on other sites More sharing options...
grandpabear Posted April 25, 2009 Author Share Posted April 25, 2009 thanks, I have the 4.0 . it's pretty low, I was just curious as to what the ratio was. I don't use 1st gear on the street, as it is too low, and offroading I use 4 low and 1st gear, and just idle over most of the obstacles. thanks again, Bear Link to comment Share on other sites More sharing options...
